Photos of Portage / Canoe Carry Signs
I actually liked that about the BWCA. It gave the place more of a wilderness scavenger hunt vibe.
In the case of the past 2 trips, however, I doubt I'd find many those portages without the signs or flagging tape. There's simply not enough foot traffic to make them the open trails that you find in the BW or popular parks like Algonquin.
I ran across these yesterday at Oil Creek State Park. First time I'd seen a portage marker in PA
This was slightly downstream (almost hidden behind tree branches in the 1st picture)
I guess I can see why they're so adamant about marking it... probably mess you up pretty bad if you went over
Oh, yeah, nevermind that sign on the right. nobody else was dumb enough to be on that snow-covered road so I thought it would be OK.
The Park Ranger says the flow is seasonal & best before the end of June. There is a short-line rail service that can provide shuttle back to the put-in. Might be a day paddle sometime this summer.
Low head dams are drowning machines.
BWCA66 makes a good point about wilderness areas. Not only are signs removed, but historic old cabins get burned to the ground by the USFS. The Wilderness Act is very specific about "the signs of Man should be unnoticeable."
The Wilderness Act is well-intended but misguided, selectively biased to accommodate hikers/paddlers with an idealized "wilderness" aesthetic. It's too rigid in its one-size-fits-all approach to management and ignores the fact that "Man" had been living in those areas for thousands of years before they were declared wilderness. I'm not advocating for motorized vehicles/boats in "wilderness" areas, but there should be a range of management strategies and designations appropriate to each area.
