- Joined
- Jul 6, 2021
- Messages
- 643
- Reaction score
- 1,184
This is the discoloration in question:
IMG-0232 by Mike McCrea, on Flickr
The backstory. That is a glass and polyester canoe, and it blemished in that fashion when new and little used. The manufacturer replaced it with an identical glass & poly canoe, which proceeded to do the same thing.
The same make/model canoe was bought at the same time in kevlar and did not discolor. Both stored side-by-side under a carport in Florida. The discolored glass & poly canoe has dark green gel coat, the unblemished kevlar version has a much lighter Sand colored gel coat.
My immediate thought was that it looked like bacterial surface growth, some dinoflagellate, algae or protozoan from a scummy water trip, or even some airborne pollen or pollutant combined with Florida humidity to form a canoe Petri dish.
Brush scrubbing the inside with a magic grime remover solution of white vinegar and Dawn did nothing, and that mix will take off even the toughest grime. The discoloration seems to be encapsulated under the resin or in the cloth.
Both canoes were factory fresh hulls, but unlike the easily dimpled foam core on a brand new Royalex canoe, I have never seen a “freshness” issue with a composite hull. Maybe still smelling faintly of resin, but that quickly faded, and I think of it akin to new car smell.
It could be the temperature difference between Dark Green and Sand colored gel coat, but that doesn’t seem likely, or it would be a more common issue in hot or sunny climes.
Same for the difference between a kevlar layup and a glass & poly build, that discoloration doesn’t appear to be a common issue. We have glass & poly canoes, and I’ve worked on a bunch of others, some decades old, and I have never seen that mystery before.
Has anyone seen that kind of encapsulated discoloration before on a composite hull before? Any ideas about how, what, why?
IMG-0232 by Mike McCrea, on FlickrThe backstory. That is a glass and polyester canoe, and it blemished in that fashion when new and little used. The manufacturer replaced it with an identical glass & poly canoe, which proceeded to do the same thing.
