- Joined
- Oct 11, 2020
- Messages
- 230
- Reaction score
- 365
Free standing screen tents are relatively inexpensive, compact, lightweight, and easy to set-up. A common flaw with many is that the bottom skirt does not securely touch the ground leaving gaps. At no cost I lower mine to eliminate the bottom skirt gaps. I shorten the bottom pole sections then move the pole connection fittings equal distance up the corner seams. Six inches may be enough to prevent the gaps but I like to move the width of the skirt. You can take it further and sew the bottom skirt corners at 45 degrees, add additional pole attachments, stake loops, and aluminum poles if desired.
Procedure:
1. Remove bottom pole sections
2. Cut bottom pole sections to desired length
3. Reattach bottom pole sections
4. Remove pole connection fittings from bottom skirt
5. Reattach pole connection fittings equal distance up the corner seam as to length cut off the pole section
Procedure:
