It was only nine years old, but the rear cross bar on my truck cap had become deformed, making some attachments difficult to fit. Some idiot had loaded boats on the bars by sliding them up from behind the truck. After a few hundred slides, hardware protruding above the gunwales had gouged the rubber coating, and then rust got busy. The bar was corroding inside the rubber, blistering and expanding the height and width of the bar.
This was one of those jobs that should take about 30 minutes, before Murphy visits. First, I couldn't figure out how to loosen the towers from the bar. Finally found a hidden tab that slides down to reveal Allen bolts that activate the bar gripper. But even after totally loosening the gripper, the towers would not budge. My choices seemed to be to remove the rubber coating and grind off the blisters of corrosion, or cut the bar. Either way, the bar wouldn't be much use. Successfully removing the bar took me a couple hours.
Now if I can just get that idiot to stop gouging the new bar with my dang boats...
