• 2026-29 Fund Drive needs only 9 MORE DONATIONS to reach target. Read the Featured Thread for details. Please donate!!!
Bright Green Stuff in the Water
SW OH - Land of Opaque Water
My last trip to the local reservoir/cesspool was disappointing. Had to drag across a mud from the beach. Couldn’t get far upstream from the lake. Paddled the Echo 2 only 2 miles at a blistering 1.8 mph in a 7 mph wind, no dog (thankfully). Taking out, I noticed bright green stuff floating in the shallows, contrasting with the normal olive pea soup color of the water. I assume this is algae, but not sure what species, how infectious it is. I rinsed everything at home, scrubbed the hull. Just wondering what this fluorescent green stuff is, and whether it dies or just gets diluted in spring. Bogan’s not going anywhere near the water until April, at least.
With all the heat this summer it's probably just garden variety Green Algae (a mix of several native algae) and relatively harmless, if you're seriously concerned about contamination- a cup of 5% bleach in a five gallon pail or straight 10% cleaning vinegar in a spray bottle will kill it on contact- but generally speaking it'll be found in virtually every waterway anyway, and is a common food source for many fish and invertebrates.
Cold weather usually kills it off once the waterbody gets below about 50F/10C, and the spores will lay dormant until spring. The only time it becomes an issue is if it completely covers the surface blocking both sunlight and O2 penetration into the water column, but generally fall turnover will return it to equilibrium...
Around here when the weather is hot for an extended period, our local lake grows floating mats of blue-green algea. It is almost iridescent. Yes, it is toxic if ingested. It does eventually die off when the surface water temps go back down, but often hangs on in the shallows. We're advised to not swim in it and keep our dogs out of it too. I've never done more than wiping down my canoe with a sponge and rinsing. We're told it exists naturally and is only a problem when it blooms - which is when you see it floating on the surface.
