• Happy Invention of Scotch Tape (1930)! 🏴󠁧󠁢󠁳󠁣󠁴󠁿🧻3️⃣🇲
4 place canoe trailer - $2195
Groveland, MA
Canoe trippers - this is the one for you.
Custom built on a TeeNee coil spring frame, this trailer has new tires, size 5.30-12, new wheels, hubs, bearings, grease seals and Monroe-Matic shock absorbers along with all new wiring and lights with the 4 pin flat connector. The hubs are equipped with Bearing Buddies. The pressure treated cargo box will carry 24 cubic feet of gear and with the canoe racks removed it will double as utility trailer. The tailgate drops to 90 or 180 degrees; the bed is 49 inches wide which allows for loading full sheets of dry wall or plywood for those other chores that do not include canoeing
Gross weight is 1500 pounds, empty weight is about 500 so it can carry a 1000 pound load.
Compare this to a new trailer if you can find one, coil spring trailers have not been made in years. They ride much smoother than the leaf spring trailers sold today.
Come with a 2 inch ball on your draw bar and this rig will be ready to go.4 place canoe trailer 002.jpg
Located in Groveland, MA
Stevens Canoe Works
978 374 1104 or cell 508 451 1941
stevenscanoe@gmail.com
