U.S. Rivers that No Longer Reach the Ocean, and Why Lakes Mead and Powell are Drying Up
"A river reaching the sea is the assumption built into the word river, and across the American West it is increasingly not true. The Colorado has not made the Gulf of California under natural conditions since 1998. The Gila, once one of the great tributaries of the Southwest, runs dry through metropolitan Phoenix for most of the year. Sixty miles of the San Joaquin simply vanished from the map for six decades. In every case the water did not evaporate or get stolen by drought alone, it was allocated, and in most cases allocated to more users than the river physically contains. Here are the American rivers that stop short, and what happens at the end of each one."
While the West has been in drought for several years, the primary reason Lake Mead and Lake Powell, the two largest reservoirs in the U.S., have declined to record low levels is because of historic over-allocation of the water of the Colorado River.
The Colorado River Compact of 1922 allocated 17.5 million acre feet ("maf") of water annually among seven states . . . in perpetuity. This allocation, unfortunately, was based on an anomalous "Wet Period." The negotiators looked at hydrologic data from the previous 20 years (roughly 1902–1921). Unbeknownst to them, this was one of the wettest periods in the Colorado River's 1,200-year recorded history. They assumed the river's average annual flow was well over 16 to 17 maf. In reality, the long-term historical average is closer to 13–14 maf, and drought has recently shrunk that to about 12 maf. Meanwhile, the population served by the water allocation has grown from 1-2 million people in 1922 to over 40 million today.
Methinks this water problem is mathematically insoluble for the Southwest USA.
Go East, young man, go East!
Over allocation is a common problem in the West.
Nevada gets 10% of the annual allocation or about 300,000 acre feet or less depending on the year.
That is 90% of the supply for Las Vegas.
Agriculture uses the vast majority of the water in the Colorado River System
Desal plants on the coast of California may be the only real solution to the problem.
Irrigation efficiency would help alleviate water shortages in the Colorado Basin, but water law requires ag users to use their water rights or lose them.
Add to that list the Snake River and Lost River in Idaho...sort of. The Lost River never did make it to the sea. It made it to the historical lava beds in the Snake River plain and entirely dissapeared there into the aquifer at or before the Lost River Sinks - hence, the name. It wasn't actually lost though because it charged the aquifer that also feeds the Snake River. Now with all the diversions for agriculture, it rarely ever makes it all the way to The Sinks. In the last forty years, I have seen water flowing in the channel near Arco exactly once, about IIRC eight years ago.
The Snake itself has been sucked dry by water users most years to the point of literally just a trickle below the Milner dam. If it wasn't for the aquifer recharging to the tune of 5200 cfs (which is about 2,000 cfs lower than historical estimates before groundwater use for irrigation became common) the stretch between there and at least as far as Malad gorge would probably be essentially dry most of the year.
while the issue isn't anywhere near extreme in Canada, many of the small brooks and streams I used to trout fish in and run in the spring are virtually gone, and of those still around many are no longer paddle-able or fishable, because too many people are drawing from them or impounding the water for their own use. A stream in my daughter's back yard has been dry for over 20 years because the region (like a county) decided to build a series of retention ponds, "flood control" ponds, and diversions that literally dried up every stream on her side of town, others are old mill ponds that have been abandoned for a century or more..
Those ponds still exist even though every one is no longer used for irrigation or drinking water, some of the dams have not been needed for almost 100 years, and have permanently changed the hydrology for the worse, with many wells having gone dry, and where the water table has dropped 10' or more causing extreme damage to the affected watersheds including altering it from upland forest ecology to savannah or grasslands, displacing both flora and fauna...
Changes in the Water Laws in the western states would reward people for conservation. Since ag uses the majority of the water, promoting drip irrigation instead of flood and sprinkler irrigation would saves millions of acre feet. Most states penalize people for not using their annual allotment when it is available. Many ag users with senior water rights could care less about using less water. They irrigate with siphons out of a ditch like Mesopotamia 2000 years ago. Sprinkler irrigation wastes a lot of water to evaporation loss in the arid West.
Lake Powell is a gigantic evaporation pond. Never should have been built. It provides little irrigation water and currently little to no power generation. Glen Canyon dam needs to be removed although it will be expensive. One of the worst boondoggles in American govt history.
The water saved would end up in Lake Mead the largest reservoir in the US. Nevada gets around 7% of the allocation of water from Lake Mead.
Conservation is the cheapest new water to be found anywhere. Why does Las Vegas still have lakes and tree lined streets? The city now pays people to remove their lawns. Much of the new landscaping uses xeriscape. Much of the old landscaping needs to be removed. Las Vegas and the surrounding towns are moving in the right direction but too slowly.
All of these problems can be solved. The use of nuclear fusion to create heat may be the most economical way to run desalinization plants on the California coast. The state is losing population. It has sufficient water but a serious distribution problem. 80% of the water use in California goes to agriculture. They still use antiquated methods. and still use a large percentage of the water use on the Colorado River. Arizona is second and Nevada is a distant third.
They have golf courses because they are a resort town. Modern golf courses built in desert cities use them as drainage ways for surface runoff during high intensity storm events. Modern golf courses often have a lot of native bush vegetation. Newer ones have a turf tee box and then the first 100 yards is native veg. They use recycled wastewater for irrigation. The fairways keep getting narrower. they have greatly reduced their water requirements.
Those are all good things, but golf courses still use 5-7% of municipal water supplies in Nevada each year. And unlike water used by homeowners or factories which is largely captured, cleaned, and reused, golf course water usage is nearly 100% consumptive - it's used for watering and is lost to evaporation or plant absorption
As with most problems in the USA, nothing changes until it becomes a monumental crisis. The warnings about irrigating deserts (including having millions of people live there) have been known for a century or more, becoming more dire as each decade passes us by. Trouble is, no one using that water seems to be willing to compromise so we'll all end up paying for it one way or the other.
And it's not just the desert areas that need to change; poor surface water policies and laws all across the country are allowing people to further degrade shorelines, stream channels, and wetlands. We've made some progress in certain areas but overall we get a failing grade.
