• Happy Birthday, Alexander Graham Bell (1847-1922)! 📞
Late Season Canoe Poling on the Union River
Up here in Maine, the last few weeks have given us enough rain to raise the rivers to a somewhat reasonable level. A local favorite paddling spot was brought back to life just in time for some late season poling. On this section of the West Branch of the Union River there are several unnamed rapids which are short Class I affairs and one named waterfall, (Tannery Falls) which is probably a Class III when it has enough water to be runnable. Alas the gift of rain was not quite enough water to run the falls without excessively battering my 40+ year old canoes, there was in fact a nearly perfect amount of water for canoe poling. So I set out over the weekend to make the most of it!
Pictured below: Tannery Falls at a low runnable level. The ledge on river right is a good indicator of when the falls are runnable in an open boat:
-No water over the ledge = not enough water
-Some water pouring over = a bumpy ride
-Water pouring over all sides = good Class III run
There is a second set of rapids above the falls that looked tantalizing as I went by it the other day, but upon heading out with the wife and baby I found that there was not quite enough water for the combination of my skills and boat handling to make a meaningful ascension. The entire river bottom was large irregular boulders which made for many places to get stuck and only a few good places to plant a pole. I had greatly anticipated showing off in front of my wife, but was rather humbled by the river that day. (Many such cases!)
Pictured below: a tantalizing rock garden above Tannery Falls and some downstream snubbing.
Having been a little morally bruised but not entirely dissuaded by the perceived loss above the falls I returned to the section below the falls just before the bridge the day after.
Pictured below: Tannery Bridge over West Branch Union River
Here I would find something a little more my speed. While I wasn't successful in pushing up the main chute of the current here, I did over the course of the outing make it up and down around a dozen times. Once I had gone upstream I performed a modest, "Rock-Hop" to turn myself around and get my weight forward of the center yoke for downstream snubbing. Each time I did so I felt better about the boat, the water, pole position and trusting that my yellow tripper wouldn't slip out from beneath my feet like a big old banana peel. I failed to set the camera in a spot to capture the action of catching an eddy with a pole, but I suppose that can be arranged on another day.
Pictured below: Poling and snubbing through a small rapid.
Linked below is some of the footage I captured from these two outings. Unfortunately due to technical issues the footage from above the falls suffered from some pretty bad compression when moving from one device to another.
It was a good learning experience and I was just happy to be on the water again. The snow coming in at the end of the session reminded me that the canoeing season is rapidly coming to a close.
Nice report and video, and a nice Tripper. That is a situation where I would have my Maine Guide Paddle. I think it pairs well with the pole. I don't know how Harry Rock feels about bringing a paddle along, but if you were tripping you would sure have one. The long paddle makes catching an eddie more similar to how you normally would paddling ww. I haven't figure out how to that with the pole.
I quite like the extra paddle length for catching eddies as well. Though the blade on my paddle being a bit narrower does make it less effective in shallow water than I would sometimes hope when compared to a dedicated rock beater paddle such as an Aquabound Edge. It probably doesn't help that I am still a bit sheepish with my paddle as I spent a lot of time making it and don't readily have supplies to make another in the event of a catastrophic failure. I'll get over it eventually I suppose.
Here's an excerpt from Harry Rock's, "The Basic Essentials of Canoe Poling" catching eddies with a pole takes a bit of finesse and I'll be the first to admit I haven't got the hang of it.
I was referring to your maple Maine guide paddle with the big blade, although on that shallow stream I probably would have stuck with the pole.
When I went to catch my first Eddie with a pole I didn't know how I was going to do it and switched to the long paddle at the last second. The long paddle made it easy, especially when standing because you are free to change your trim to facilitate it. When I thought about this later I remembered that a canoe pole is also called a "setting" pole. This is because you typically "set" your boat into the eddie, which would be entering the eddie with a back ferry, stern first. This prevents having to turn the boat around and getting broadside to the current and takes less space.
Eddie turns are fun and look cool. I think they require a paddle to to do well. When I was on the Oswegatchie river the pole and MGP combo worked great. I got pretty quick at switching back and forth between the two.
Great looking Tripper! I have a two of my own, as well as a Hobie 16 catamaran with two yellow hulls, which we call the "Double Banana," so I especially appreciate your Chiquita sticker.
I'm an aspiring poler and am glad to learn that the Union River is a good spot to practice. A good friend and tripping-buddy of mine lives in Castine, and works in Ellsworth, so I'm in that neck of the woods once or twice a year. I'll be glad to seize the chance the next time I'm around. Maybe we'll cross paths.
That's one of my favorite things. Catching a small eddy behind a rock is tricky indeed, but bigger eddies in deep water are pure joy. The technique for that works as well as any paddle, once you get the hang of it.
Skip to 11:10 in this video to see the best example I have. It's fairly weak current and a small boat, but the move is essentially the same in bigger water or bigger boats. It's just a skinny crossdraw, but with more reach and more leverage. I need to get out and do more poling videos....
At 15:10, I'm using the same technique to peel back out into the current.
Riffle-Raff, thanks for your fascinating report and video! What a beautiful river! I am a "retired" solo paddler who knows very little about poling. So have a couple of questions. Do you always paddle upstream on your poling trips? Does your wife paddle her own canoe? Or were she and your baby watching from the riverbank? Have you ever poled thru Tannery Falls?
I almost always go upstream when poling. Its fun to strategize and pick your way upstream. I'm not overly keen on snubbing downstream, although I can understand the merits of it from a historical standpoint when you would be navigating rocks and the like with a fully loaded wood and canvas canoe. While I am comfortable going downstream with a pole it rarely feels quicker or more enjoyable than paddling downstream.
I wouldn't personally pole tannery falls although I'm sure someone could do it. The drop is steep, and the ledge at the bottom is treacherous, it really wants to pull the bow to the right while the current wants to pull the stern to the left after. The current is fast and there are very few safe places to lodge the pole upon descent that wouldn't result in it being wrenched out of my hands or otherwise ending up in the water myself.
Nice report and good explanations. I was amused by the idea of showing off to your wife. It reminded me of an occasion where I was going to show of to my wife. We were running a chute and I told her what I was going to do. She pointed out that there was a boulder in my path, which save us both a swim.
Boy, my poling streams haven't had enough water for good fun in months....I'm glad (and jealous) you were able to get out there, @Riffle-Raff !
Last spring when the water was up I was practicing eddy turns with a pole per Rock's book. Still have lots to learn but I felt like I was making progress. Unfortunately there aren't that many good eddies to practice around me unless the water's pretty high.
I've been dithering on getting a drysuit for a few years. Seems like the window between being out of hypothermia danger and water levels dropping is all too short most springs. But I'm also not sure I'd really get out often enough to justify the cost.
I personally don't get out enough to justify a dry suit either. This is actually a combination of a splash jacket and dry pants. I got the top at a thrift store oddly enough and got the pants at a steep discount because they were 10yr old dead stock at a paddle shop. I do some spring whitewater so they're worth it for the peace of mind for sure.
Steve, thanks for sharing your video...you make poling look so easy! Here in central IL, have never seen folks poling their canoes...then of course we don't have many rapids in our creeks!
I haven't checked in on this site for a while. I was happy to see that poling is being discussed and practiced. I will just share my YouTube channel for those who are not familiar. I always feel like laughing when someone comments that they don't often see polers in their area. I see exactly none in central Ontario, Canada. I do live in hope. Canoepoler channel on YouTube
Thanks for the link, Steve.
No other polers in my area either. I've tried to recruit some, but can't seem to get any interest.
Steve, is that a Home Depole?
I had to take a close look because my first pole was a Home Depole, and I sometimes still use it. But no, that one is my hybrid version, carved from an ash plank and crowned with what is essentially Ed Hayden design aluminum pole ends. Six inches of aluminum tube topped with delrin plug, steel washer, nut, and grade 8 bolt with the head ground off. Heavier than a full aluminum pole, but quieter and warmer in the hands. Heavier but longer wearing than the HD pole.
I'm afraid the idea of the Home Depole may be lost to history. When I made my first one, I had to pick through a couple dozen fir closet rods to find one with straight grain and no runout. I went back several times later looking for material to make a spare, and never found another suitable pole. Everything was crooked or prone to splitting at the runout. Eventually, they quit stocking fir pole stock, and switched to hemlock.
I found a straight hemlock pole and made one from that. It's lighter and stiffer, but has the slightest bit of grain runout. I never found any hemlock stock with no runout, and that grain wants to peel up into little wooden knife blades. I don't recommend hemlock for canoe poles.
I kept hoping they would go back to fir, and last time I was in HD (about a week ago) I noticed some nice looking closet rod stock that was pretty straight. Close examination revealed that it was all made up of short lengths finger-jointed together. I wouldn't even hang shirts from that, let alone use it for a canoe pole. :(
I envy those guys who have local access to spruce pole stock.
