• Happy Birthday, Mae West (1893-1980)!📽️⭐⬆️🅲🅼🅴⌚
1960s fiberglass canoe restoration?
CT & NY
I'm debating on what to do with this canoe. If I hadn't been paddling it for 60 years, I suspect I wouldn't even be thinking about it...
Around 1963, Dad happened on two canoes that were "excess" to a bunch of canoes bought by some unknown camp. He took one and a friend took the other. We kept it at our NY cabin, my sisters and I learned to paddle in it and used it a lot (lake flatwater only) until we gave up the cabin. Dad took it with him when he moved to NH but gave it to me some years later when he bought a modern Kevlar canoe... and when I returned to the cabin community years later I brought it with me, back to the same lake where its mate still resides. But having just finished the restoration of a much nicer canoe, I really don't need the old blue monster. It's 15' long, 36" beam, very stable, and heavy (though I haven't actually weighed it).
One winter when I was around 14 years old, we took it home to try paddling on some local rivers. Stored on sawhorses on the patio for the winter, a wind blew it off and against a tree, cracking the hull across the middle. 14 year old me said, "I can fix this!" and I did, with a very crude and ugly fiberglass job. I should be embarrassed over the workmanship, but it's held up for 50 years... I would have painted it, but I wanted to paint it green and Mom wanted to keep it light blue, so it never got painted.
Then some time later a buddy and I foolishly tried to run a whitewater stream with it. It's heavy and tracks straight (making it a favorite in 4 man event in the annual canoe regatta), but doesn't turn so good, so we plowed into a rock. Hit hard enough what my buddy who was in the front ended up in the water and I who was in the back ended up in the front of the boat. That must have been around 30 years ago.
It's pretty beat up elsewhere, and one of the old fiberglass patches is finally peeling off, but it still floats.
Fixing it doesn't seem too difficult: Fill the gouges with filled epoxy or resin, redo the peeling fiberglass patch and smooth out the intact ones, and paint it (and fix or replace the cracked aluminum seats)... but the last thing I need is another project, and I really don't have a place to keep it. It'd be a good loaner but I have access to plenty of other canoes owned by my neighbors. But if my kids or neighbors don't want it (I'd kinda like to see it stay on the same lake), then I'll have to decide what to do with it.
Some equipment just hangs around for decades. It is easy to get attached to it.
Fiberglass that old can become very brittle and not very serviceable. Take an objective look at the boat in strong sunlight.
Tap on the hull, Use a knife on the trouble spots. If it is still sound you can make some improvements. Some boats just need a dignified death.
I have a 1929 Johnson outboard in my garage that has been in the family for 75 years.
It looks like a decent enough canoe, but I wouldn't get too carried away with repairs. Check it all over for soft or crunchy spots. If there aren't any of significant size, I think it may still serve well as a dedicated lakeside cabin canoe - where the weight wouldn't be an issue. If it's gone soft or brittle, maybe it would make a good planter?
It's solid but heavy; even moving it 30' from the rack to the lake is a struggle. If I can convince my son in law to take it problem solved; I'll help but he can do all the work. ;)
Sometimes we get canoes like this one offered as a donation at the nature center where I volunteer. I would just as soon the director not accept them but she almost always does because she doesn't want to discourage donations. So we keep them for awhile then I saw them up so they will fit in the dumpster.
So if you have someplace to keep it for sentimental reasons do so, otherwise it may be time to let it go. And I like Gamma's idea. If I had a cabin and a canoe with those memories I would it keep for display. The missus would never allow me to bring it home.
Well, it's no doubt silly but I guess I have to fix it up, if only for my own satisfaction, even if I end up giving it away afterwards. It's actually very well behaved on the water. So I stopped at West Marine yesterday for some more fiberglass cloth for the sides and some G/Flex for the keel; we'll see how far down this rabbit hole I end up going... 😵‍💫
Good on you!!
I have some stuff that will live long useful lives, after I’m gone. I’ve told the history of each and every person that I have earmarked these treasures for. I have typed up, printed, laminated and attached the history of each one also. I have also did the same to some other stuff that is of value, not of the sedimental value sort. Old bamboo fly rods are not to be use to stake out tomato plants.
I hope my two sons don’t saw my cedar & canvas Seliga canoe in half to make a book shelf to house my autographed Sig Olson, Cal Rustrum and other choice books.
In that case, I'd say it's earned the rescue.
If nothing else, it will be good practice. ;)
When looking for something else I pulled a box of photos out of the attic and found this... it's my sisters and I in 1965 in the very same canoe. I was 5, my sisters were 10 and 14. It looked a bit better then...
Sometimes the memories are of higher value than the actual object, that alone says to restore it if possible, or let it live on in another life.
I've seen old, unserviceable canoes turned into bookcases with the centre section modified for a coffee table, (shave the keel, cap the cut ends, add some blocks to the edges if needed, and slap some glass on it), i've also seen one turned into a massive light fixture over a dining table- hung upside down by a couple of chains to hang it set up like a towing bridle, run the wire down through the hull to the under side of a gunwale, drill holes for lights, and daisy chain them all the way around, or put LED lighting tape on the underside.
Unfortunately for me, none of my old canoes are around- two were stolen, two are impromptu underwater reefs, and several were just plain beat to death...
