Any Advice for Spray Painting Interlux Brightside Polyurethane Enamel?
Have the old fiberglass canoe all sanded down and want to use a HVLP gun to apply the paint. Never used this paint before, have heard to thin it 10% at least and not go over 60 psi.
Anyone with experience with this paint?
Thank you in advance for any tips.
I have used Interlux Brightside many times but have always applied it with a foam roller. Using a foam roller and a disposable foam brush to tip out the marks and little irregularities that the roller leaves can actually give you a finish that looks sprayed on. When using the roller make two quick passes over each area at right angles to each other. Immediately tip out the paint that the roller applied with a foam brush. It is easiest if you have an assistant following behind you to tip it out.
