• Happy National Garlic Day! 🧄🚫🧛🏼‍♂️
Scarfing jig
Mid coast, Maine
I offered to give a tutorial on hooked scarfs and nibbed hook scarfs so I took the time yesterday to put it together. A plane scarf joint can slide apart when it is clamped, a hooked doesn't. The jig I made almost thirty years ago is a bit big for this size work although I have done it, I decided I needed a new jig more appropriately sized. So this is my old one it is 52" long and can scarf a 4" piece at 12 to 1.
The new one is but 19" overall and let me state right now, although it looks like it was all thought out ahead of time that is not the case. There were a lot of happy accidents, but that is the way I seem to work. Here are the two side by side.
Here is a close up of the jig. I've alway clamped and wedged the pieces into the big jig, and that is what I thought I would be doing with the little one. So I drew on the 12 to 1 slope (I like that ratio, but you could shorten it if you like, it doesn't matter and everything will work the same.) on some Baltic Birch plywood scrap I had. It was just the length I needed. Rummaged around for a piece of wood for the base and found a nice piece of mahogany with a good thickness and just a bit longer than the plywood. I cut the long tapers on the plywood aligned the pieces on the base board and glued and screwed everything together. Then I saw the cut off wedges from the plywood ants thought they might work for my usual wedging as I did with the big jig. But then I had the thought to put threaded inserts for screws use to clamp everything. Luckily the base piece was the perfect width to accommodate, totally unplanned. The base and side connection must be strong because the wedges and now screws on the little one try and wedge it apart. Here is the competed jig. All the pieces I had around the shop, I had the knobs, but bolts or screws could be used.
I used the clamping caul to draw a rough taper on the rail stock samples.
Rough cut them on the band saw.
Both pieces get clamped in the jig at the same time. I used pine and mahogany so the contrast shows the joint better. You can also see how close the jig pieces fit, totally unplanned.
I set up a little trim router with a wider base that I can see through, bit size doesn't matter but I used a 1/2" straight bit. Set the bit to trim the entire length smooth.
It now looks like this.
Next drop the bit a small amount. I didn't measure but it turns out it was about 3/32" and 1/8" I think would be too big but it doesn't matter. Then start another cut from the top going down into the scarf and that extends the length. Just do a little bit and stop.
Then measure the now total length from the feather ends to the new top end. Divide that length by two and draw a line across the scarf face.
Now continue routing down to the line. I never go all the way to the line, the next step is to chisel to the line after it is removed from the jig.
As I said the next step is to remove it from the jig and chisel to the line. It should now fit like this if you measured correctly.
So there you have it, a hooked scarf. It took longer to photograph the process than to do the jiont. It will satisfy most needs for a scarf joint so I'm going to stop here for now while the process sinks in and I'll show a nibbed hook scarf later. It truly interlocks and is mechanically stronger but not sure it is necessary for a canoe. Questions and comments of course are welcomed.
Not really a case of "mad skills" if I did it all with hand tools yes but..... I look at it as more of a recipe that I've perfected over the last thirty years. If you can build a canoe, or put new rails on a canoe you can do this scarf joint. Just a little care in assembling the jig and you are good to go.
Lovely results. Every time I try to build a jig for something like that, things get... interesting.
I could see using Mahogany or Walnut and Maple, Alder or such to do an intentionally contrasting finished product...
Excellent !!
I see one in my future !
Adding a dovetail bit, would be a cool thing. I like how you solved the problem of slippage in the joint
Thanks Jim !
Thanks Jim. No dovetail bit needed, just a straight bit any diameter will do. This is a very old traditional joint in boatbuilding, "I" didn't solve anything. The long feather ends on the scarf are not good on big boats and would be the first area to let go. Hence the nib ends that I'll show in the next installment, perhaps tonight if I have time.
I've done a lot of these, but if you want to be conservative when drawing the center line, draw it further up the slope or don't cut as close with the router. It is real easy to chisel cut a couple times till you get the ends to fit just right.
Very nifty. Had to read through it a couple times before it all sank in. Glad this was re-linked in another thread. I was on a trip when it was originally posted and missed it.
Thanks for sharing,
You're welcome Alan. I really did intend to do part two showing a nibbed hook scarf. Not really that applicable on canoe rails but an interesting next step.
