I do love the discussion and ideas floated (pun) on CanoeTripping, and there’s no time like the present to experiment.
Questions and concerns were raised about the (not good) visibility of dark dry bags after a yard sale. I have some (compression) dry bags in stupid black, and a bunch of DIY heat sealable bags in dark blue. Not the best colors for recovering floaters.
I also have a few designated dry bags marked with enamel paint pen contents; Spares & Repairs and group 1[SUP]st[/SUP] Aid kits, and an off-season compression bag of spare clothes. The black clothes bag is already more contrast visible with just the yellow block lettering on the ends
P3240001 by Mike McCrea, on Flickr
That black dry bag is only yellow lettered on the two compression ends, maybe not the best for high visibility recovery without a direct end-on view.
P3240004 by Mike McCrea, on Flickr
Yellow striping dark dry bags for contrast with an enamel paint pen was dead simple quick and easy, and even so I got better at it after the first stripe.
Empty dry bag, laid flat on the bench, alcohol cleaned swipe, let dry. I put a yardstick across the bag and ran a yellow paint pen across that guide. Moved the yardstick ¼” below that yellow stripe (¼” being the width of a paint pen tip) and widend the stripe with another paint line so it is closer to ½” thick.
P3240006 by Mike McCrea, on Flickr
Finished in minutes. I tried making a wider stripe at first, but filling in between the lines was a PITA compared to just zipping a paint pen across the surface twice.
Eh, not finished. I need to add a couple more stripes to the black clothes bag; the top stripe was (thoughtlessly) positioned and will be hidden under the compression end cap. That one needs a couple more easy-peezy yellow paint pen stripes at the bottom of the bag for a better high vis bee stinger.
P3250012 by Mike McCrea, on Flickr
The stripes on the blue canoe taper bag are better located, but the lines could (should) be more distinct yellow, my yellow paint pen was running dry even before I started on the black bag.
P3240007 by Mike McCrea, on Flickr
P3250014 by Mike McCrea, on Flickr
I use the yellow paint pen a lot, and the black one even more often. Not so much the red or blue.
P3250009 by Mike McCrea, on Flickr
Time for a new yellow paint pen, and easy yardsticked stripes on all of our dark bags.
heck, maybe black paint pen stripes on our yellow and orange bags; I can see how having instantly identifiable “Them’s mine” striped dry bags could be a boon on group trips or trailer shuttles.
If I had better memory for pattern recognition it might even help me remember what was packed in which dry bags; one stripe, two stripe, yellow stripe, blue stripe.
