Anyone installed kayak style footbraces on a canoe? The crossbar type won’t work for the new boat.
Well, it would work with an extended outter tube. The problem is I want to maintain gear capacity, as well as flexibility to sit in the stern or bow seat. I installed one on my last prospector 15 for paddling from the bow seat and it wound up crossing just beyond the yoke. I’ll have to see where my feet hit, but I’m thinking it will be too intrusive for maximum payload and trim adjustment. If I can make one cross brace work for either seat position without intruding on cargo areas I’ll install one. I think that’s why I installed the adjustable rail on the aluminum track in my last prospector, but I’m not certain.I believe Hemlock installs them on the SRT regularly, but that’s a pretty narrow boat. A guy I met at the Ozark Rendezvous I believe had a set installed on a Yellowstone solo. Just epoxied in like the cross bar style brackets are.
Just out of curiosity, why won’t the cross bar style work on the new boat?
Nice boat Cruiser, do you paddle it with a single blade?Standard on my solo builds, link to that, in last build
Light Weight Solo Tripper Build
This post will cover off some of the finishing steps as we move to final fit and varnishing. Normally, I would have completed the yoke by now and started finishing the gunnels ... but I "had an idea" and the router bit I ordered and require, is taking forever to get here, so the yoke is on hold...www.canoetripping.net
I personally don't think they'd be worth the inconvenience they will create. I've never felt that they would help me get to where I'm going any faster as I can already get as much power as I need without them. I like my seats high, at least 11 inches, and can get all the leverage I need. They could possibly help with a lower mounted seat though. Other than that they might help keep you comfortably on your seat with a little pressure, but I think too much pressure with your legs will sap energy that isn't going into your paddle.
