- Joined
- Mar 21, 2015
- Messages
- 437
- Reaction score
- 19
So, I've had a summer to digest what I learned from my experimental build last winter/spring, and overall, I think I'm ready to improve on the next one. Many things went right, many more went wrong and were corrected.
Then, there's this:
I'm very disappointed with the way the interior glass turned out. the cloudiness is not just dust. The camera exaggerates, but not much. I only got six or seven full days on the water. Here's the specs for the surface:
So.... Any experienced epoxy guys and gals out there that recognize this set of symptoms? How can I check?
Then, there's this:
- Single 6oz e-glass
- Wet-out was System Three clearcoat
- "Partial fill" - added a couple of layers of resin, but did not try to fully fill the weave - wanted a little tooth in the surface. System Three Silvertip resin.
- Three coats System Three wr-lpu (Very odd stuff. Love it for some things, hate it for others)
- Some of this is very near the surface. When I sanded to get some tooth for the cleats, the finish improved quite a bit.
- Some is very not near the surface. Down the center, sanding had no effect - the cloud remained.
- UV breakdown. Seems logical, but the outside of the hull has the same layup and finish, has racked up even more sun exposure (driving around on top of my car) and does not show this flaw.
- Scuff damage. I've found that the partially filled weave tends to trap the local river sand-silt mix. I've had to use a stiff brush to get it out at times. Does not match with the fact that some of this is definitely below the surface
- Amine blush or other resin cure issues? But then, why did it not show up in the original build? I've gone back and checked the pictures.
